Hi. Brand new to the forum and look forward to conversing with the knowledgeable folks here as I get out of my comfort zone with this new-to-me motor. As background, I just picked this up off Craigslist. From the exterior it looks hardly used, which I guess is a good sign. The people who sold it had never used it and they bought it from a widow whose husband had used it when new and then after he died it sat in storage for many years. The prop came off very easily and it was well lubed, so I'm not sure if that's original or if someone did some maintenance at some point in time.
I plan to do some of the routine items over the winter and am starting with the impeller. I got the prop off and removed the lower unit. (Excuse my terminology if I'm off on a few things.) After removing the two bolts for the lower unit, I had to yank a little bit to get the lower unit to disengage and come off. Hope that's not a bad thing--guess I'll find out when I go to put it back on.
So, my immediate question is whether I should clean up everything seen in the picture (except for the old impeller which is being replaced). There is a fair amount of grime (from exhaust?) around the inside of the lower unit and the housing for the impeller. If so, how do you clean this up, and do you lube everything after? As you can maybe see, there is a slight bit of rust color on the gear shaft, and also down where the shaft heads into the lower unit. The gear shaft itself is also very "dry" whereas most everything else seems to be lubed/greased. What/how do I tend to that?
Thanks for your wisdom on this or any related issues!
