1992 25hp evinrude rectifier replacement
johnfn65
I was in the process of changing out the rectifier on my engine when I got called away and was gone long enough to forget the wiring pattern.
I have on red and three yellow wires on the rectifier, coming into the rectifier there are 2 yellow wires with a blue stripe, one yellow wire, one grey wire and the red wire.
Can any one tell me the proper placement of the yellow wires and the grey wire coming to the rectifier?
boobie
Re: 1992 25hp evinrude rectifier replacement
The grey wire goes to any one of the yellow wires as it's for the tach. Make sure the red wire goes to the battery.
johnfn65
Thanks for the reply, would you know what order the yellow wires with the blue stripes go in?
boobie
It really doesn't matter.
