Re: 1999 evinrude choke operation
Hi Ben, welcome to iboats.
Different motors have different controls. On my outboard, you pull the choke lever out, then start the motor, then push it in. The center button is actually the kill switch. Users won't be able to help you with the limited information you have provided. Go onto the motors section of iboats and post your question in the section relating to your motor. Good luck!
