Re: 96 evinrude timer base
Thanks for the model number. The looper or crossflow refers to the V configurations of the OMC engines. OMC still made the V4 crossflow engine through the 96 model year. You have a 3 cyl inline engine, all of which have been loopers for years. If you are having ignition problems, there is an excellent source for troubleshooting information on your engine: cdielectronics.com Your engine's information starts on page 40 of their troubleshooting guide. There are numerous tests which can be run to test voltage output on both the stator and timer base. (you'll need a special "peak-reading" type voltmeter to do these checks.) The voltage tests will indicate if either device should be condemned (replaced.)
