speckman6408
- Aug 24, 2008
- 30
Hello Guys: I have the above motor and man it is trying my patience, which is about 1/32" long.
I have a good spark on both plugs-the spark is real blueish and it will spark 3/4" from the spark
plug port. I tried holding the end of one of the plugs and it gave me a good charge--enough that
I didn't repeat on the second plug. I have disconnected the rubber hose going into the carb and
the pump is pumping gas. It still won't crank! I have sprayed a little gas/oil mix into the carb
throttle, and it still won't crank. This motor has a rope pull and so I took the cover off and got me
a socket and short extension and put it in a 3/8" drill and it will turn the heck out of the motor, but
still I can't get it to crank. I also sprayed some gas/oil mix into the spark plug ports and I still
can't get it to crank. I checked the compression with both plugs out(the plugs are brand
new)and I am reading 120psi on the bottom cylinder and 125 psi on the top cylinder. I also had the
carp throttle open during the testing. Can someone please help me? I am 69 years old and need
to go fishing on the bayou. I appreciate and thank you for any input!
Do you know where you were 50 years ago today? I do, I was in basic training at Fort Polk, La.
Any one that has been there knows that the sand hills there, is a plague that Pharoah did not have
to endure!
to endure!
