Re: 1984 Evinrude 150 stator
I'm assuming that in testing for spark, you have all of the spark plugs removed, a known good fully charged battery, and that the engine is cranking over at least 300 rpms... needed in order for the stator to energize the powerpack properly.
Your post above #19: Okay, understood... there is no ignition on the starboard bank regardless of what you switch around.
You have the following components installed: New Stator, New Timing Base, and known good powerpacks and coils... and in switching these items to the port side find that they do cause ignition to exist on the port side... BUT even with these items connected properly (port & strb wired properly), you have eliminated the kill circuit to starboard by disconnecting the black/yellow wire from the powerpack... BUT still have no ignition on the starboard bank.
Am I correct so far? If so............
(Electrical Pins/Sockets - Poor Connection)
(J. Reeves)
The electrical rubber connectors that house a series of Pins and Sockets within them have a flaw which can easily be overlooked. The pin or socket (or both) has a habit of being pushed back slightly in the procedure of pulling that plug apart and pushing it back together when replacing a component or doing test work, resulting in a poor connection or none at all.
Also, the wire that is attached to these pins and sockets has been known to break away from the pins/sockets which results in either a very poor or no connection at all. I've found many instances where the wire is held tight in the rubber connector by pure friction but in reality is not making any connection.
Be sure to check all of those rubber plugs for the proper pin/socket position and their wiring attachment.
