Re: Evinrude 9.9 change to 15 hp carb
Most people who've done the conversion are disappointed. You might get a little more speed at WOT only, but starting and idle suffer. And there's no difference at lower RPMs because the bigger carb throat doesn't help when the throttle plate is closed.
