brokenjack
- Sep 16, 2013
- 25
The shift lever is pretty hard to move back and forth, and I think I need to get the power head off to clean out the old grease and crud and re-lube the inner workings. Manual says I need to remove the flywheel/carb etc. The engine runs pretty well, and I don't want to mess around with that much removal. Can I take the powerhead off without removing everything the manual says? I know the obvious things to disconnect, but the manual seems to suggest overkill. I already have the lower unit w/driveshaft off to do an impeller install.
Thanks for any advice
