I'm looking at buying a 2003 G3 jet boat with an '03 4-stroke 2-cylinder 80hp jet on it. I took it out for a test drive yesterday and the engine sounds great but there seems to be an issue with the jet drive. When we floored the accelerator, it sounded like the jet had sucked something up in it (revving up and not getting full thrust). The boat ran fine at lower speeds but struggled to get on plane with three people in it. The owner thinks that the jet drive is just taking in too much water and needs to be shimmed. Does this sound like a plausible solution? If not, what else could it be? I don't mind spending a little bit of money to get it running right, but if it could take a grand or more I'll just look elsewhere.
