111torrance111
- Jan 8, 2006
- 273
Tried a simple water impeller replacement and ran into a stripped bolt in the lower unit.
When removing a stubborn lower unit I put pressure the back nut and stripped the threads, now I need to replace it and it's stuck pretty good and need advice.
I tried putting two nuts on it and removing with the bottom nut, but the bolt wont hold.
I'm soaking overnight with some WD-40, but not sure if that will work.
Any advice would be good.
Jerry
Jerry
