I have read on several older threads about multiple different things that could create the black oil substance running down the front of the midsection. It comes from under the lower cowling and you can see it is coming from under the the power head area but can't see exactly where it comes from. I am understanding that it is unburnt oil but I would think this should run out of the prop. The motor runs great and is worth a minor repair cost to me since I can't afford a new $10k motor. What does anyone think can be done and how hard is it to do. I am relatively mechanical and have replaced pretty much all of the electrical components, epoxied new magnets on the flywheel, new water pump assembly, etc. so to do the work myself is an option.
Thank you!
Thank you!
