Took the lower end off my motor. Impeller looks good, seemed to be low on gear oil. Splines all look good. My question is how easy should it be to move the shift rod up and down?
Normal. There are detents in there to make it snap in and out of gear. You have to apply considerable pressure to overcome the detent spring and make it "snap".
