Danielschultz
- Jun 28, 2010
- 3
i have been looking around online for recommended spark plugs for this motor and i found this website Johnson which has been very helpful but i noticed something that doesn't make sense the title of the page is for 10 hp johnson motors 49 - 55 and as i scrolled down i found the spark plug recommendation but there is a typo in there i am sure, this is what it says "The recommended spark plug is a Champion J6J, now J6C, however with a well used motor most old time mechanics would recommend a hotter plug, like the J8C especially if you do a lot of trolling. Or if you opt for the NGK brand, go for BR6S-8. These plugs use the 3/8" reach, so do not try to use the 1/2" reach ones off the 9.9hp as the electrodes will become smashed by the top of the piston." ok the title says this is for 10 hp johnson this says the spark plug is a j6c or j8c and they are 3/8" reach but not to use the 1/2" reach off the 9.9hp i might be wrong but the 9.9hp is the 10hp motor i think they only made a 5.5 hp and 10hp nothing inbetween i know they made larger ones. so can someone tell me where the typo is or better yet just what spark plug to use.
