dkonrai
- May 9, 2009
- 719
i have a clean 1980 15 hp short shaft, the lower bearing is shot (pretty sure it squeals at low idle.) motor is really clean and i think the bearing failed from non use. lower is great overall its clean.
now i bought a johnson 1996, 10 hp that the mounts are shot, as well as other items. can i put the ph on the 1980, and swap the ignition and flywheel? never thought of frankenstein'g a motor, but, just thought id ask. it would make life easy, and i would have a new style ph, with the greatness of the 80's carb and over built durability. (the newer has too much plastic, and i hate the plastic carb)
thoughts? am i crazy for thinking of doing this? the drive shaft is the same, and i have a tuned exhaust housing as well.
dino
dino
