Re: Tilt trim pin on a johnson 2003 40 hp.Having trouble removing it. Any suggestions
i just realised how dumb that reply looked. I'll check it out. Thanks for your help.
I had the same problem and tryed all of the above suggestions, soaking for days, heat, slide hammer, every thing without luck, the pin would only move about 3/4 of an inch. Finally resorted to a cut off wheel to get the unit out than drilled most of the remaing to releave the pressure and than was able to push it out. Now I have to do the same on the pump unit and hope not to damage it. This motor has only been used in salt water and the pins never been removed before, from now on every year the pins will be removed and greased.
