I have received as a gift from my Father-In-Law a 1982 90hp Evinrude w/ tilt and trim and a 20" shaft. The motor has sat covered for 2 1/2 years but he claims that it ran perfectly prior to that. The motor seems to be in good condition. I've pulled the plugs and have manually turned the flywheel. I can see all four pistons moving up and down the shafts. My next plan is to spin it with the starter so I can check compression. Could anybody please give me some advice on what steps I should take to get this motor back running without ruining it in the process. Thank you!
