Martin Devault
- Nov 3, 2013
- 6
I had to remove my lower unit on my Johnson 1990 70 hp with the VRO. Everything was alright. Now i am trying to reinstall it but i am not able to attach the shift rod to the shift link. The shift link it's under the Vro pump and unapproachable unless i remove the VRO pump. Do i have to to that or their a more simple way. I ajust the lenght of the shift rod (21 23/32''). I try the opposite of when i remove it (pull the shift lever) but nothing to do. I only have reverse. thank you very much for yours helps.
