Re: What would be the dry weight on a 1965 40 hp Evinrude outboard motor?
+1 the '65 40hp weighs about 130-140lbs. Generally speaking, newer motors of similar hp actually weigh more than the vintage models. Particularly if it's a 4-stroke engine, which can weigh 30%-40% more than their vintage, 2-stroke cousins. Of course, if you add electric start, electric trim and tilt to the modern motor can weigh even more. While some new motor have better fuel consumption on paper, their extra weight can often offset some of the savings.
