Hi all,
I have a 1993 evinrude 200 ocean pro, I bought a power steering unit for it on ebay, I cant find any docs on how to hook the oil cooler into the engine cooling system. If anyone has this set up, please post pictures.
Thanks, Mike
Is this a hydraulic steering system? The gurus will have to answer your question but I've never heard of any oil that has to cooled by the engine, The ones I've seen simply have the oil lines run from the steering wheel back to the connecting cylinder at the motor. Maybe that what you actually have. Good luck
