Duckman224
- Oct 30, 2013
- 4
Was hoping for some insight on a problem that is driving me crazy!! My 83 evinrude 35 ran beautifully for 2 years it then started to cough and sputter after putting it into foward and accelerating. There seems to be a certain rpm range that the motor will run really bad even coughing and stalling itself out, however if I drop below that rpm range or go above it the motor runs fine. I have rebuilt the carb and adjusted everything according to the service manual checked the fuel lines and pump and everything appears good. It also seems to be worse in the colder weather . To me it seems like a carb issue but I just can't figure it out. Any info would be greatly appreciated.
