I just got a Evinrude 155hp V6.. The motor is turning over very slowly, so I had the starter rebuilt..I put the the newly rebuild starter on and now the motor is still turning over slowly but this time, my battery cables and are getting hot. I need some help figuring this out.. Could it be the cable coming the battery to the starter solenoid or the solenoid itself. What would make the battery cable it really warm... Also when I turn the key switch off, the motor kept running the off position, I had the disconnect the battery the stop the motor from turning over..The batteries are fully charged.
Thanks,
mav
Thanks,
mav
