Re: 1986 johnson 110hp still won't start
Compression, spark, fuel = running. How many times have I heard that.....But....is the spark happening at the right time? If it were me, I would mark the flywheel location of TDC for each piston. You will end up with four marks, 90* apart. Remove plugs, insert screwdriver carefully, and rotate flywheel by hand. Feel when the piston gets to top dead center, and paint a white mark on the flywheel adjacent to the timing pointer. Then, replace plugs, get timing light set up for looking at #1, and crank it over. You should see the white mark for #1 at or near the timing pointer. Do the same for the rest of the cylinders. If you do not have spark at the right time, then two things can be a possibility....someone has been monkeying with the primary leads to the ignition coils, and has them connected wrong, OR you may have a sheared flywheel key. If you have timing out of whack, it should backfire, loud like a shotgun out the prop. Does it?
