mysearay38
- Jun 11, 2012
- 33
I have a 2001 21ft walk around seaswirl with a 2001 200hp evinrude flich . I was docking the boat going in reverse put the boat in forward and gave it gas and the boat keep going backwards. I lost neutral and forward. I guessing my shifter cable broke. Took cowl off motor moved the shifter and the throttle cable move but the shifter cable did not. Tried to take shifter lever off side of boat but could not. there was a small cover on back side of shifter lever. took that off and then took the four bolts out of shifter lever and there was one bolt in front of shifter lever took that out too but could not get shifter lever to come loss and could not lift boat panel up that has the shifter lever is on. Am I missing some bolts?
