vasportsman
- Oct 28, 2013
- 3
Hello all, new to the forum as I just became a boat owner.
I have an 82 Johnson 25hp 2 stroke pull start tiller style outboard attached to a 16 ft Jon. When I bought it, it ran great, started right up, was perfect. The next time out, had a few problems, and wondering if anybody has experienced anything similar or knows what is wrong.
First, noticed that in addition to exhaust there seemed to be steam coming out of the exhaust, or what seemed like the exhaust, honestly I have not been able to nail down where it is coming from, and the exhaust does not come through the propeller.
Second, the upper part (out of water) of the lower unit was very warm/hot to the touch.
Third, the telltale was warm, but not hot, and had a steady stream, not pounding, but not trickling either.
Fourth, after running for awhile (10 mins) at higher RPMs, it began to slip out of gear and rev high with no forward movement, I would let it come down, and it would re-engage at low and made it back to the dock with no further problems not running above about mid speed/turn.
I have been trying to diagnose the issue, and drained the gear oil and found it to be a bit milky, which I understand is a sign of water intrusion, and very green in color (is that just a function of the kind of oil?) I have refilled it, however it did not take hardly any gear oil, and not much drained out, but was overflowing out of the top fill hole when trying to add more. I plan on a test run this weekend hopefully, either just off a dock or in a garbage can.
Gear oil issue, or something more problematic?
Thanks!
Thanks!
