Re: Are Johnson 1960 18hp Seahorse & 1959 18hp Seahorse parts interchangable?
These old FD/E models are great motors and easy to date. I have a '66 20hp myself, which is an FD-20 a '65 is an FD-19, '64 is an FD-18 and so on. You'll want to run 24:1 fuel oil mix along with Champion J4C or J6C spark plugs on your particular models. If you had a post '64 models you could use 50:1, but I always err on the side of caution with these old girls and use a little extra oil. While I could run my '66 motor at 50:1, I perfect to use around 32:1. It makes a little puff of smoke on start up, but otherwise burns pretty clean and provides a little extra security.
