Big Claude
- Sep 10, 2013
- 11
I have a 1992 Johnson Faststrike 150 with a bad rectifier/voltage regulator. The manual is not clear on the removal of the retifier and I would like to know what is involved in replacing it. Is there a gasket or an o-ring underneath the unit? I know its water cooled but most replacement units do not offer the rectifier with a gasket so I am in question about its removal. Is there anything I need to look for to insure it is getting properly cooled? The wiring looks pretty simple, just unplug old and plug in new. I imagine the battery needs disconnecting before starting. Any help will be appreciated.
