My engine backfires at idle just a loud POP and then it will idle fine for a couple seconds and repeat I found a YouTube video showing the same situation and it was a loose hose on the inlet side of the vro pump?
Could it be the vro? its been deleted or bypassed but I'm not sure its been done properly? are there things I can check to make sure it has been done properly?
I'm very unfamiliar with the whole VRO system but pretty good with my tools, carbed two stroke outboards and problem solving just need to know where to start besides getting a manual (its on it's way)
I just bought the boat today and it sat for two years until Friday the previous owner rebuilt the carbs Sunday supposedly ...
If I do a drop test pulling the plug wire on the #4 cylinder makes it stop backfiring idles normally when I pull the plug wire but it sounds kinda high though (Lean maybe?)
looking at the back of the motor here's a diagram (not sure if I got the cylinder # right or not so this will save some confusion)
-----------------2 1
this plug ----> 4 3
---------------- 6 5
this is on the hose btw and ill post the model number in the am when I get home tomorrow morning
Thanks ahead of time !
Levi
this plug ----> 4 3
Levi
