uminchuman
- Apr 17, 2009
- 5
I can't get the propeller shaft out of my Johnson 75 (Stinger). I have the drive shaft (or output shaft) out and the pinion gear out of the way. The shifter is pushed down into reverse and the shift rod is out. I think the propeller shaft should just pull out. It feels like something is holding it. Is it possibly just 'tight' and needs more force to get it started moving??
