Re: 1985 johnson 90 hp motor run awesome - changed new starter now wont start
Have you looked at the spark plugs? I was working on one of these, the bottom spark plugs were wet so i thought they were flooding, i tried to light it later with a flame and it was water. Head gasket was leaking slightly on both sides which i hadnt picked up with compression test..
so check for that and also check the colour of the plugs, do the two on the top look similar to the bottom two?
if that doesnt show anything. Pull the safety line off on the control so you wont get spark and then turn the motor over a few times, check all sparks a wet with fuel, if not then a carb/s could have a blockage.
If that doesnt work check timing. Advancing that spark is probably just putting more work on the cyliders that a working rather than getting all four working properly.
Yes NZs a good place to be now-we a anti winterising here unlike the northern hemisphere people
