Chesapeake Rob
- Oct 10, 2013
- 1
First of all I should have my butt kicked for buying someone else's problems! Too late. I bought a 1989 88 hp evinrude, the first time that I had it out it seized up after a couple hours of running a trout line, let it cool and got it to break free and start and made it back to the ramp with no problems. I pulled and cleaned the heads, changed the diverters, replaced all the internals in the thermostat housing because someone had taken it out, and put in a new water pump. After these repairs the motor continued to shake and miss during idle, found that a cylinder wasn't firing and found the power pack to be the issue. I replaced the power pack and two coils and the motor runs worse then it did before. Sounds like it back firing through the exhaust like it has a timing issue. Can anyone point me in the right direction?
