'98 johnson 115 hp has always run poorly since bran new at low speed, often conking out while trying to dock. Could changing the spark plug gap from .030 help?
Re: 1998 Johnson 115 hp plug gap to run better at low speeds
It tells all about it in a factory service manual. I can't type that long to go through the procedure. It has to do with getting your carbs and ignition in sync.
