I have a 74 Johnson 50ESL74M that I can't get to run long enough to adjust everything. I already know it has low compression on one cylinder, 90 lbs on one, 150 on the other. Could this be the cause of it not running good or should it still run with those numbers? I've been told it should still run but might be down on power a little bit. Please reply with any opinions, I'll gladly try anything at this point.
