jake_A.S.24
- Oct 13, 2013
- 9
first a little history
i got the boat and engine along with the trailer 3 years ago. i finally got the boat all sanded on the outside and lights working on the trailer. so after that i turned to the engine, i needed to get a fuel line for it before i could do anything as well as some muffs. oh, the engine hasn't been ran for about a total of 8 years.
Problem
i tried for a while to start it in neutral but nothing (dry start) finally i flipped it into gear and it started right up. it scared the crap out of me and i shut it off instantly. after purchasing some muffs i started to check and make sure i got water going through. and i did. now i can get it started here and there but it doesn't want to stay running. it seems to start after i prime it up a little and it runs a couple seconds but stalls. tomorrow im going to try and prime it as i get it started which could mean my seal on the tank is bad. i believe i have a pressure tank. also, i have yet for it to start for me in neutral, the only time i can get it to start seems to be in gear. i have started it in gear and put it in neutral and it stayed running.
does anyone have any other ideas as to what it could be?? any help would be appreciated.
Problem
