Taxus812
- Aug 5, 2013
- 173
Keep forgetting to post this.
When I remove the cover and look inside the below the carbs I always see oily residue. I wiped it all out then ran the boat. Looked again and it was back. I removed the air cleaner and there doesn't seem to be anything dripping.
I was wondering if the residue is normal for a two stroke (caused when I tilt the engine up allowing what is in the carbs\intakes to leak out. )
Unfortunately it rained heavy for so is looks more wet than oil in the picture
