Good morning all,
I would like to install a temp gauge on my johnson 140. It is currently wired for the temp alarm horn to sound when it over heats. I was wondering if I could disconect the brown wires from the horn in the console and connect them to temp gauges. I am not sure how temp gauges work but I read about some that you hook up to a head cover bolt and then that wire sends the temp to the gauge. Is this some special wire or could the brown wire that is already hooked up to a heat sensor in the head work and save me from running new wires? Also should I put in two gauges? one for each head or should one give me a pretty good idea of what the other is doing? I dont want to smoke another piston because one side over heated and the other was running nice and cool.
Thanks,
Dan
Thanks,
Dan
