Jim Hawkins
- Mar 11, 2013
- 499
I went to change the gear oil on my 1987 Johnson 30HP. I should have done this when I first got it, but I didn't. After running it several hours I decided not to push my luck. When I removed both plugs nothing came out. When I began pumping new gear oil in on the second pump a blob of brown oil came out the top hole and on the third pump the new oil was coming out. It could not even have taken 1 oz. of oil before it overflowed at the top hole.
Short of disassembling the lower unit, any suggestions?
*Note - running the motor all seemed well and shifting was Very smooth.
