nate_camille
- Sep 19, 2013
- 5
I was given an old 1964 Evinrude 18 HP (Serial 18042) by my dad. He got it from an old friend of his. The motor sat on an engine stand for about 10 years. I went through the motor completely and did the following:
1) Replaced seals and impeller in lower unit. Replaced lower unit gear oil. Old oil looked fairly good, but it was sitting for a long time, so for good measure changed it anyway. Didn't see any water or milkly color in old oil. Gears all look great.
2) Took carb completely apart and cleaned. Used rebuild kit to replace everything expect the float (which still looked good). I set low speed mixture screw at one turn out to start.
3) Checked spark plugs and cleaned them up. They looked like new almost.
4) Put a little oil in cylinders before cranking engine over.
5) Cranked engine to verify good spark on both cylinders. Everything looked good.
6) Cranked engine and it started on first pull.
7) Water pump is working well
I had the engine out on a lake, so I let it warm up for a bit but it kept acting like a cylinder was misfiring (engine would jolt a little) with RPM's on the low end. As long as I kept the RPM's up towards the upper end it ran fine. If I let the RPM's down, it would start acting like it was misfiring and then die if I didn't give it gas.
I did put it in forward and give it some gas and it was running fine. Slowly brought up RPM's and let the engine run for about 5 min at about 1/2 speed. Then slowly raised it up to top speed and it was running great. But as soon as I bring it down to low idle, it acts up again.
Not sure what to look for as the culprit at this point.
