Becauseican
- Jun 15, 2010
- 54
I have a 73 85hp Evinrude that was not firing.I removed the kill wire and the rectifier wire and it started up.The motor would not switch off so my son in a panic touched the kill switch to the power pack to try to shut the motor off instead of just chocking it.Well it hasn't fired since.I baught me a dva adapter and began trubleshooting following the instructions from the cdi website. The resistent on the stater and the sensors #2 to #4 and #1 to #3 was good. Stator was a little higer that spec like 750 or so. Done the dva on both and both were within spec.But when i check dva on sensor to ground i get nothing.When i remove trigger wiires from pack and retest still nothing.The instruction don't say what is faulty when this is happening. I am assuming the Power pack but want to ask someone elses opinion.Thanks for any reply.
