Hey Everyone! I recently purchased a 1986 Johnson 110hp model # J110TLCDC ob and am having trouble with spark. Ive purchased a gap tester and tested each wire from each coil and the spark barley jumps a 1/4" gap. I've installed new plug wires and tested the resistance on each coil which all seem to be within spec via cdi testing charts. Also determined that I'm not getting any fuel on one cylinder which I am going to address with carb tune ups and cleaning. Motor ran when I got it but during water testing it was very sluggish and only went about 10mph at WOT. Stator seemed to be within specs as well but I'm not sure I'm testing it correctly. I tested between the brown and the brown/yellow wire. I'm guessing a bad power pack but don't want to just throw parts at it in hopes to solve the issue. If anyone has had similar problems and could assist me I would be very grateful.
Thanks!
Thanks!
