87 Johnson 90 HP Outboard Tach?
frankk
I just purchased a Lil Hobo which has this outboard on it. Is there a tach output on it? How can I determine if I can hook up a tach to it? Frank in Antioch, IL
Daviet
Re: 87 Johnson 90 HP Outboard Tach?
Does this contol look like yours?
#50 is the plug for the tach, do you have one on your control box, if so the tach plugs into it.
:: iShopMarine.com ::
Barnacle_Bill
If you don't have that connection you can still add a tach. Its just a little more complicated.
emdsapmgr
OMC provides a gray tach signal wire to the control box for running one. It may feed the tach plug that Daviet mentioned, or it may just be curled up inside the control box-depending on the year of the box.
Daviet
If you don't have the 3 wire plug on the control box as in the parts breakdown in post #2, you are going to have to open the control box and look for a gray wire as emdsapmgr mentioned in his post.
frankk
Thanks guys... something to search for when I get back on Sunday.. So sounds like if all I have is the gray wire then I use discrete wiring / resistor / meter then. No problem with that. Thanks for the support
