drivin-fool
- Oct 2, 2013
- 1
Hi all. My brother has a 1997 Evinrude Intruder 150 V-6 which has some sort of issue going on, and I hope maybe someone here can help us track it down. The motor cranks up fine, and every now and then at idle it will hiccup. When out in open waters it will run fine, then it seems like it coughs. When this occurs, it is usually only for a second or two, but on occasion it has continued. This only happens every now and then. He has had it to two different mechanics locally who cannot seem to get the motor to act up. The entire electrical system has been looked at, and none of the wires seem to be broken or damaged.
For what it is worth there is a white milky looking fluid on the port side exhaust port. The motor has good compression, and all of the carbs were checked and everything seemed to be in order. Thank you in advance for any guidance or suggestions you may have.
