I am a first time boat owner. I recently purchases a 1981 16 ft aluminum monark boat with a 70 HP outboard Johnson.
My issue is: I rebuilt the carbs and put in a new starter switch. The engine will fire but will not start. Problem is that even with the key not in the ignition when i test for power on the starter it shows as hot. and the engine fires when I turn the key to the on position not the starting position. The previous owner wired around the safety switch on the control box. Should I purchase a new OMC control box with a safety switch? ARe my current issues keeping the motor from starting?
The boat has electric tilt but the tilt is not on the control box it is on the dash next to the steering wheel along with 3 other switches for the pump and lights.
Thanks!
Thanks!
