So here's the deal. Earlier I had posted problems with this engine being difficult to start while warm. Now the problem is that I only have sporaticly intermittent spark on the top cylinder. Here's what's been done so far to try to track down the problem:
1) All ignition related items have been either replaced or have been swapped from one cylinder to the other. Swapped the coils, points, plugs and condensers. No change.
2) Replaced the sparkplug wires with brandnew ones. No change.
The bottom cylinder has excellent spark. The top cylinder has an occassional sign of life with a somewhat weak blue spark. I'm sure my cordless drill is providing ample RPMs.
HELP!
HELP!
