Let's get this out of the way first...I have very little motor experience. Hence my reason for the post.
I have a pontoon with a 1999 50HP Evinrude 4 stroke that runs perfect at low throttle. The engine is quiet and provides a smooth ride. When I start punching it down to full throttle, it starts missing. For lack of a technical term, it get herky-jerky. I just had the impeller replaced at a shop and it seemed to run fine prior to the service. It's new gas also, so that should not be an issue. This behavior was observed the first time back in the water following the impeller replacement.
The pontoon is a 1996 and the guages do not work properly, so I cannot give exact rpm's where the engine performance deteriorates.
Are the most likely issues (1) clogged fuel filter or (2) bad spark plug(s) ? Could the shop have messed something up during the impeller replacement?
I appreaciate any input and ideas where to focus my attention. Thanks!
