While out on the lake today, I went and tried to start my 90 HP evinrude engine. It tried to start but then quit firing. I pulled the cowl off and noticed that the bleeder valve(thats what I call it) was gone. It looks like the valve stem in a tire.
I believe it is used to bleed the air out of the fuel line if you run out of gas. The valve stem is missing along with the cap. I have tried to find it on the parts list but I can only seem to find the cap. This is a 2001 90 hp Evinrude. Can anyone shed any light on this?
After checking further this looks like a test port. Apparently it is to check the fuel pressure. I don't understand why it is not listed in the parts manual.
