I'm helping my neighbor with his no-start 1998 Johnson 50hp 3cyl outboard. I'm pretty good with 4 strokes but have very little experience with 2 strokes. We replaced the stator back in August because with ohmmeter we were reading open at brown to brown/yellow. (didn't have dva adapter at that time). Still no spark. Then we replaced power pack because the trigger seemed to be putting out voltage using a Fluke meter on ac and just took a guess that the trigger was functioning.
New power pack,still no spark. So we figured we'd go with the trigger because,what else is left. We did eliminate the kill circuit and rectifier as possible causes early into this. Well we just got the new trigger and a dva adapter just in case.Installed new CDI trigger and guess what? Still no spark! Took reading using the dva, and checking the individual trigger coil outputs (white to Purple,blue and green).:grumpy: I had 0 volts with connector disconnected and 5 volts or less with connector connected (should be 100v+). White to white/black read 0 volts connected or disconnected. Old trigger and new trigger are both reading about 300k ohm although CDI literature says it should be 1M ohm to 2.4M ohm using a Fluke Meter.
Flywheel looks good with the 6 stator magnets in tact and in place. The only thing left is the trigger magnets that are pressed into the flywheel. Not sure but there appears to be 2 magnets and they do display magnetic attraction.
More test results: Brown to brown/yellow is 214v connected and 250 v disconnected. Orange to Orange/black is 14v connected and 42v disconnected. The power pack resistance readings are right in line with CDI specs. Unless I got a defective trigger, I'm out of options, I think. Is there some way to be sure the trigger magnets are ok? I also removed spark plugs to take away any loading on the ignition and give me a higher cranking rpm.
Any other suggestions would be GREATLY APPRECIATED!!!
Thanks! Vince
Thanks! Vince
