J48ESLESA
Had to replace the tilt motor in May......hydraulic cylinder was not leaking then......after about 5-6 weeks of use
the motor started to hesitate before starting to lift......it got progressively worse and then the cylinder started
leaking ......I need to rebuild the cylinder but am having a hard time finding a rebuild kit for this unit.....lots of
kits out there for other models but not this one.......any ideas?????
What would cause this cylinder to leak when it was working good when I replaced the trim motor??
