I purchased a long shaft conversion kit and the 5 in. extension that came with it is part no. 304136. It looks right but when I go to bolt it up I can get 3 of the 4 bolts in it but when I go to put the 4th bolt in the holes do not line up perfectly.I can get it started but you can see that the bolt is cocked slightly and Im not about to force anything.Any help here would be greatly apperciated..Thank you
