Hello
Have a 1992 Chris Craft Caper 156 with a 1992 60 hp Evinrude engine.
The spring in the ignition switch went bed keeping the starter engaged. The local parts distributor here in SWFL suggested the MP39760 switch as a replacement. The first problem is that the letters from the new and old switch do not correspond exactly. Spent many many hours and several days without success of the entire process working correctly. Have contacted Sierra without success of any assistance. The Chris Crafts manufacture sent some info but not enough to get it done. If any one has knowledge of this issue or where it can be found it would be greatly appreciated.
Thank You
Thank You
