Powhatanjoyce
- Sep 20, 2013
- 5
Hi guys i have a question I've seen all over the net but haven't seen the answer I'm trying to find out... On my 1978 115 hp evinrude i have water pouring out of the exhaust water ports as soon as i start running the motor.. and i mean not a sputter but like my water hose is just running through it.. Now i know that water should come out of those holes. But should it be that much that soon or should it be less at first till the motor has warmed and the thermostats start to open.. when i first got the motor running it didn't seem to do that . water didn't just start pouring out like that but the last couple of times it does.i have water coming from my tell tale hole just for info so the impeller is working.. I'm just not sure if the thermostats may be stuck open ..now i know i should change them anyway since i just got the motor but from what I've read this seems to be a tough job because of placement of the tstats placement of the lower cowl.... Thanks for future responses
